E-GMP KIA/Hyundai ICCU
pms
Data de Aquisicao: 01 ago 2023
Capacidade bateria: 150 Ah
Mensagem por pms »
Já há algum tópico a discutir a situação da ICCU na plataforma E-GMP KIA/Hyundai?
Apanhei um post no sub-reddit do IONIQ 5 de alguém que fez um apanhado de vários fóruns coreanos sobre essa situação com a ajuda de IA e tem informações muito interessantes.
https://www.reddit.com/r/Ioniq5/comment ... d_insider/
Segundo o mesmo em 2028 sai uma arquitectura completamente revista e com essa situação completamente resolvida:
5. The Future: Integrated Modular Architecture (IMA)
To permanently resolve the systemic vulnerabilities of the E-GMP, HMG is transitioning to the next-generation Integrated Modular Architecture (IMA) for widespread deployment by 2028. This platform structurally eliminates single points of failure through several key shifts:
Zonal Control Units (ZCUs): The IMA completely abandons the centralized ICCU and domain-based wiring. Instead, decentralized ZCUs distribute power based on geographic locations within the chassis.
Solid-State "e-Fuses": The self-destructing mechanical high-voltage fuses of the E-GMP are replaced with software-resettable e-fuses. These smart switches detect micro-shorts in milliseconds, dynamically isolate faults, and instantly reroute power to preserve drivability.
In-House SiC Development: By decoupling hardware from software and bringing critical Silicon Carbide (SiC) component design in-house, HMG aims to master thermal tolerances and prevent the silicon degradation seen in the first generation.
Também dá nota de alguns motivos internos do R&D da Hyundai que atrasaram/dificultaram a resposta:
3. Organizational Dynamics: The Blame Game and Corporate Delay
Rather than a cover-up to protect a specific executive, insiders attribute the delayed response to systemic and financial calculations:
Namyang R&D vs. Hyundai Mobis: A friction point exists between Hyundai’s Namyang R&D center (which created the system specifications) and supplier Hyundai Mobis (which manufactures the hardware). R&D cites assembly quality control, while Mobis points to unforgiving architecture specs.
Cost vs. Global Recalls: Rebuilding and physically replacing every ICCU globally presented a multi-billion-dollar logjam. Management initially relied on software service updates (NHTSA Campaign 24V-204) to lower peak currents and widen warning windows, which bought time to re-tool manufacturing lines but failed to reverse physical silicon degradation.
E pelos vistos os Engenheiros de R&D queixaram-se de tolerâncias, requisitos e calendário muito apertado no desenvolvimento da peça/sistema:
Narrow Tolerances: Current and former R&D engineers indicate that components were specified with narrow thermal and electrical safety margins to meet tight weight, size, and unit-cost budgets during a rushed development timeline.
Numa nota positiva, a Hyundai/Kia aumentaram a garantia desta peça até aos 15 anos ou 300.000 km—ainda bem. Alguém confirma que em Portugal está extensão da garantia da ICCU também já se aplica?
Diário de Bordo - EV Database
Associado UVE
Re: E-GMP KIA/Hyundai ICCU
Há um.topico onde isso já foi falado, onde alguém questionou qual era o problema.
pms
Mensagem por pms »
Sim, foi num DB, Kia e-Niro kony76. Mas um tópico genérico onde colocar não havia.
Associado UVE
Voltar para “Hyundai”
