France and the UK will run out of fossil fuels within the next five years
http://www.theverge.com/2014/5/16/57238 ... five-years
The UK will run out of its own gas, coal, and oil within the next five years, according to a report released by the Global Sustainability Institute at Anglia Ruskin University. And France, which continues to rely heavily on nuclear energy, could run out of its remaining fossils fuels within the next year, reports the BBC. This means that the two countries could soon become completely reliant on global fossil fuel suppliers such as Russia, Norway, and Qatar.
"Much of the discussion about ‘Peak Oil' overlooks the fact that oil is unevenly distributed globally," the researchers write in the report. They note that Kuwait has more than 700 years of oil left, but countries like Japan have very little, which means they are highly vulnerable to market fluctuations. Overall, however, "the clearest conclusion to be drawn is the vulnerability of Europe," the researchers write, because current oil reserves and consumption rates indicate that the region has the lowest number of years left.
France and UK will run out of fossil fuels within 5 years
Re: France and UK will run out of fossil fuels within 5 year
Infelizmente perante estes dois factos:
- Portugal: petróleo zero, pouca expressão da mobilidade elétrica
- Noruega: principal produtor europeu de petróleo, maior mercado europeu da mobilidade elétrica
Só posso pensar que o fim do petróleo no Reino Unido e França não vai dar em nada.
A esperança é que o aumento da procura de automóveis nas economias emergentes faça o preço do petróleo subir.
- mikexilva
- Moderador Global
Eu acho que isto é consequência de miopia politica (falta de visão a longo prazo) e abuso da cabeça dos outros (zé povinho) para mal praticar a técnica de aprendizagem às cabeçadas na parede... que já nos deixou mal por várias vezes e infelizmente se nada mudar deverá voltar a acontecer no futuro..RJSC Escreveu: - Portugal: petróleo zero, pouca expressão da mobilidade elétrica
Essiemme
Tenham calma.
Sou a favor do fim do petróleo MAS, não esqueçam, a escassez deste seria terrivelmente nefasta para todos nós!
Contudo, também acho que a implementação da mobilidade elétrica terá de ser bastante acelerada.
Não esqueçam também que, muito depois do transporte individual ser transformado, ainda há muuuuuitos outros (aviões, barcos, indústria, etc, etc) que terão de ser convertidos.
...a não ser, claro está, que apareça uma forma milagrosa de fabricar combustível a partir de recursos renováveis... (ironia ?!?)
Estou confuso...
sm
Estou confuso...
sm
11 Barras.
+ de 222.800 KMs
+/- 84,55 SOH
+ de 222.800 KMs
+/- 84,55 SOH
O petróleo deveria estar a ser guardado para fabricar plásticos, tintas, fibras sintéticas para texteis, medicamentos e todo o tipo de produtos químicos que é onde realmente é necessário e não a ser queimado...
Não se esqueçam que um VE leva muito plástico (até para isolamento dos fios), verniz nos enrolamentos do motor, tinta, óleo para o circuito de travagem e caixa redutora, etc...
O petróleo vai continuar a ser necessário até para fabricar VE's e por isso temos que parar de o queimar o quanto antes.
- mikexilva
- Moderador Global
Concordo, devíamos estar a poupar o petroleo à queimada, pois é útil em muitas coisas que o usam de uma forma "renovável" os plásticos usam petroleiro mas duram uma vida...RJSC Escreveu:O petróleo deveria estar a ser guardado para fabricar plásticos, tintas, fibras sintéticas para texteis, medicamentos e todo o tipo de produtos químicos que é onde realmente é necessário e não a ser queimado...
E eu sempre fui adepto de introduzir alterações abruptas quando queremos corrigir algo que já está mal há muito tempo, pois em vez de se ir fazendo cocegas a ver se a coisa endireita por mais uns tempos...
E muitas vezes as coisas só mudam quando não há mais "mama"...
