Fitting a Drive Recorder
"I run these in all my cars, so having had the LEAF for a day it was time to fit one.
This is based on the Blackvue 400v2 Drive Recorder, but they are all powered in a similar manner as so need wiring in the same.
First, attach your drive recorder in the desired position.
I favour behind the rear view mirror, with the lens right in the middle of the screen.
In this position you can't see it when driving.
[IMG]http://img692.imageshack.us/img692/1782/blackvue1.jpg[/IMG]
[IMG]http://img823.imageshack.us/img823/5594/blackvue2.jpg[/IMG]
Then you need to run the cable out of sight, unless you like them trailing across the cabin and using up the 12v socket under the Sat-Nav unit.
In the LEAF I tucked the cable behind the shield for the auto lights/wipers.
[IMG]http://img201.imageshack.us/img201/1374/blackvue3.jpg[/IMG]
Then the cable was pushed up under the leading edge of the headlining and run to the passenger (UK) corner.
[IMG]http://img94.imageshack.us/img94/3486/blackvue4.jpg[/IMG]
Then run round the top of the A post trim, it just pushes in with the lining bouncing back afterwards.
[IMG]http://img839.imageshack.us/img839/6125/blackvue5.jpg[/IMG]
Next you fold the rubber seal back between the door frame and the A post and work the cable into the 3mm gap between the two that runs right down to the dashboard.
[IMG]http://img28.imageshack.us/img28/6605/blackvue6.jpg[/IMG]
This keeps the cable completely hidden from sight, right down to the fuse box in the passenger (UK) side of the dashboard.
[IMG]http://img534.imageshack.us/img534/8941/blackvue7.jpg[/IMG]
It's then a matter of fitting a socket (same as the 12v feed under the Sat-Nav) in the hollow like this:
(camera played up here, pic from a Skoda, but process is the same)
Use a piggy back fuse to plumb it in, I piggybacked off the top fuse, which is 20A for the 12v OEM socket.
Use a 3A fuse.
[IMG]http://img542.imageshack.us/img542/6083/blackvue10.jpg[/IMG]
Pop the cover back on the fusebox and you now have a drive recorder that goes on and off with the ignition.
[IMG]http://img685.imageshack.us/img685/6020/blackvue8.jpg[/IMG]
How it looks from the outside. (I need to straighten it a little bit)
[IMG]http://img826.imageshack.us/img826/5914/blackvue9.jpg[/IMG]
Test run in full HD. (1080)
Happy (safe) motoring."
Em: http://www.leaftalk.co.uk/showthread.ph ... e-Recorder
- ruimegas
- Gestor do Forum
