Nissan LEAF price to drop
[IMG]http://www.leaftalk.co.uk/attachment.ph ... 1322911628[/IMG]
Electric car will be updated in two years' time and could cost less to buy
"Nissan is planning to introduce an updated LEAF in around two years' time. Talking at the Oppama facility in Japan where the Leaf is made, and where Nissan revealed more about upcoming hi-tech charging systems for the EV, a source told Auto Express: "We are hoping to bring the cost of the batteries and electric components down to make the Leaf more affordable."
Currently the Leaf costs around £26,000 after a £5,000 Government grant is taken into account in the UK. Our source wouldn't be drawn on exactly how much cheaper the revised car would be as a result of reduced component costs, but even a reduction of around five percent would drop the price by almost £1,500. And it could be even more.
As well as being more affordable there are also expected to be gains in range and performance when the revised car arrives in 2014. Before then, though, Nissan's luxury arm, Infiniti, will launch an electric compact hatchback using technology from the LEAF and with a design inspired by the Etherea concept car.
The next electric vehicle in the line-up will be a light commercial vehicle – similar to Alliance partner the Renault Kangoo EV – with a 'luxury' electric car also on the drawing board too. And that's not it, either. Our source also revealed that a small, supermini-sized electric car was in "the planning stages".
Nissan has ambitious plans for electric vehicles and has a target of selling 1.5m EV models by 2016. Currently, the firm has sold just 15,000 Leafs throughout the world since its introduction in December 2010.
Nissan plans to offer special charging systems to allow Leaf owners to power their homes via their car from Summer 2012. 'Home Smart Charging' sees a special box installed at the owner's home, which allows the Leaf's battery to be used to store energy from the grid and power the house. It makes use of cheaper overnight electricity.
The system will cost around 500,000 Yen to install in Japan (around £4,000). Nissan says that the average house typically consumes 10-12kWh per day, while the Leaf has a 24kWh battery – making it powerful enough to supply home electricity.
Nissan has also developed a wireless charging system, whereby owners simply drive their car over an induction coil which charges the battery. This can be installed at owners' homes.
It takes the same time to deliver a full charge as a conventional plug (around eight hours) but no leads or plugs are required. The only change to standard Leaf is the addition of a pad on the battery system and some updated software.
The system is only available on new Leafs and cannot be retro-fitted. Owners must pay extra for the pad and the charging system to be installed at their homes. It will be available from 2013. Nissan is currently working with Toyota to standardise induction systems to reduce their cost."
Em: http://www.autoexpress.co.uk/motorshows ... z1fT9mREn7
- ruimegas
- Gestor do Forum
Re: Nissan LEAF price to drop
Bom dia Rui Megas,
Excelentes notícias sobre o futuro dos Ev´s e do Leaf em particular.
Quero agradecer a sua amabilidade e disponibilidade na ajuda que prestou no passado domingo na estação de carregamento rápido da A5.
Ainda tentei mais duas vezes e deu sempre "cartão não autorizado". No entanto quando cheguei á zona do Parque das Nações em Lisboa, no primeiro posto em que tentei carregar, não tive problema nenhum e carregou completamente.
É de facto estranho e tem sido recorrente acontecer-me isto ao cartão.
Tanto aceita o cartão à primeira, como pode ser à segunda, terceira ou nem sequer aceitar.
Tenho reclamado junto da MOBI.E e assim continuarei a fazer até o porblema estar solucionado.
Em relação ao cabo adaptador, não tendo eu qualquer conhecimento de electricidade, pode me indicar se existe algum local onde possa adquirir um já feito?
Mais uma vez agradecido,
H Sanchez
H Sanchez
- ruimegas
- Gestor do Forum
O prazer foi todo meuhsanchez Escreveu:Bom dia Rui Megas,
H Sanchez
Em relação ao cabo adaptador lamento mas desconheço se existe feito ou onde se pode adquirir.
Cumprimentos
Notícias lixadas para quem já comprou mas esperançosas para quem ainda está apenas a ambicionar adquirir um Leaf, como eu.
jfreire
- Data de Aquisicao: 0- 4-2018
- Capacidade bateria: 115 Ah - 12 Barras
Quer dizer... isto durante os próximos 20 anos vai ser como os computadores na década de 80: ficávamos desactualizados passado um ano!RJSC Escreveu:Notícias lixadas para quem já comprou mas esperançosas para quem ainda está apenas a ambicionar adquirir um Leaf, como eu.
Abraços!
- Filipe
Atenção ás notícias deste Auto Express, pois apesar da data apresentada Nov 2011, no artigo do Sr. Sam Hardy, devem ser anteriores
( penso que em Nov. de 2011 já havia bastante mais que 15K Leafs vendidos em todo o Mundo ) pois já há outras evoluções em relação
a alguns dos temas abordados.
