http://www.appbrain.com/app/nissan-leaf ... oid.nissan#
LEAF official Android App chega ao outro lado do Atlantico
- mikexilva
- Moderador Global
Dei com isto, mas não aparece no android market oficial (pelo menos cá em PT), será que só está disponivel nos states?
- mikexilva
- Moderador Global
Re: Android App para Carwings
Parece que é mesmo verdade
segundo este site:
http://www.androidpolice.com/2011/07/28 ... ctual-car/
Nissan has released an application today that's going to make their two-dozen LEAF owners very happy: an official LEAF app that allows you to directly control features in the car from your Android phone.
Jokes aside, the app is actually very neat and packs in some really futuristic features. If you have an active CARWINGS subscription, then you can view the battery's current charge level and even begin charging the car remotely from your phone if it's connected to a power source. The application will also be able to tell you how long it is until the charge will be completed.
Other features made available through the app include the ability to remotely control the climate control system in the car, so you can have it all warm and toasty by the time you get in to drive. You can also see the remaining driving range.
One feature I would like to see that isn't included in the application is the ability to view any charging stations near to your current location. This would be especially useful on the road, as your phone could interface with the car's satellite navigation system to provide information about charging stations throughout the country. It could also alert you if there is a charge station just within your remaining driving range.
Considering that this is a 1.0 release of the application, it's a great start and will hopefully make its way into Nissan's future electric offerings, too.
E afinal está disponivel no android market em:
https://market.android.com/details?id=c ... oid.nissan
Mas infelizmente não aparece disponivel para Portugal
This app is incompatible with all of your devices.
ADP1
This item cannot be installed in your device's country.
Nexus One
Não me parece que seja uma limitação dos 120V nos EU em vez dos 230V cá na europa... e se for por causa de estar com as unidades em milhas, também é facil de resolver, mas entretanto podiam disponibilizar a app como está. Mais uma vez somos prejudicados por estarmos em Portugal... ou temos que voltar aos tempos dos aparelhos que traziam um CD de instalação com o software e drivers ?
ADP1
Nexus One
- ruimegas
- Gestor do Forum
Re: LEAF official Android App chega ao outro lado do Atlanti
Lá teremos de esperar....até quando
Não há maneira de enganar o servidor de modo a poderem instalar o software? No meu Iphone consigo fazer isso.
- mikexilva
- Moderador Global
Sim, existe uma app chamada Market Enabler que permite simular que estamos a usar um SIM card de outro operador (tem uma liista extensa de operadores) e no meu velhinho ADP1 com uma ROM não oficial, consegui instalar a aplicação simulando o T-Mobile (US).
E entrei no modo Demo que funciona bem com qualquer modelo de carros, mesmo os mais velhos a gasolina como é o caso do meu, e experimentei ligar o ar condicionado estando dentro do meu carro, e assim que a ventoinha começa a andar nota-se logo uma sensação de fresco (se não estiver calor na rua, e abrindo as janelas do carro ao mesmo tempo que carregamos no butão do telemovel)
Infelizmente esta app Market Enabler precisa de mexer em ficheiros do sistema e precisa de acesso Root, ou seja só funciona se o Android estiver "Rooted" por otras palavras ou se está a usar um ROM não oficial (Pirata) ou é preciso dar uma martelada (depende do telemovel) mas pode ser que esteja para breve a app na europa..
https://market.android.com/details?id=c ... ketenabler
Em Inglaterra tb usam milhas? e na Irlanda? estes devem ter mais peso que nós para apressar o aparecimento da app nos outros mercados...
Bem, eu já vos resolvi o problema, já não precisam de acesso root para alterar o operador de rede reportado ao market.
Penso que todos saibam instalar uma aplicação a partir de um ficheiro apk, certo?
http://hotfile.com/dl/125325194/20f476e ... F.apk.html
Agora quero uma volta de LEAF.
- mikexilva
- Moderador Global
Eu ainda andei a tentar encontrar o ficheiro .apk no meu telemovel, pois no meu Android anterior tenho ideia de ter uma pasta de Downloads com estes ficheiros, mas neste não o consegui encontrar.
Quando queria instalar um apk copiava o ficheiro para o cartão SD (ou via PC ou fazer download directamente do telemovel) e depois usava o ES File Explorer ( https://market.android.com/details?id=c ... ndroid.pop ) para abrir o respectivo apk que ao abrir perguntava se queria abrir logo com o installer.
Só é preciso algum cuidado adicional com apk's fora do Android Market oficial pois não estão sujeitos a qualquer controle de segurança, e existem algumas que são clones das versões oficiais com trojans.
Mas tendo em conta que este ficheiro tem o mesmo tamanho, deve ser a mesma versão que está no Android Market oficial.
Obrigado pela contribuição
- ruimegas
- Gestor do Forum
Acabei de instalar a aplicação no meu Nexus S e.... NIM
Posso correr a aplicação em demo
mas não consigo registar-me com a minha password
Em conclusão, temos de esperar pela versão europeia ou portuguesa
- Filipe
Estive a contar os MILISEGUNDOS que o RuiMegas demorou a tomar conhecimento da divulgação desta Androide Application,
não foram muito mais que uma mão cheia deles.
- ruimegas
- Gestor do Forum
Filipe Escreveu:Estive a contar os MILISEGUNDOS que o RuiMegas demorou a tomar conhecimento da divulgação desta Androide Application,
