Open Vehicle Monitoring System
ICEM4N
- Proprietário Ion
- Data de Aquisicao: 20 set 2011
- Capacidade bateria: 40.8Ah
Retirei esta informação de um post que abri no MyImiev
Hi,
I am trying to check remotely battery status while charging. I am out of ideas, anyone manage to do it?
Its important when we travel and sometimes I go check if it's still charging, but when I am far away i keep thinking if is charging or for some reason it stopped...
Well, if your car has the MiEV remote, you can check using that, but it may stop charging if you do while on level 2.
What I use is the Open Vehicle Monitoring System. This is a module that gets installed in the i-MiEV and connects to the OBD port. It sends data to a server which is then accessed by a smartphone app. This, by default, gives you much more flexibility in distance from the car, as well as additional information such as location, estimated range, SoC % readout, line voltage and amperage when charging, motor, inverter, and battery temperatures, and charging stopped notifications.
Of course, it requires a prepaid SIM card, but those can be had for as little as $8 a month. If you have decent Sprint coverage, PTel is probably the most affordable. This is who I use.
Hi,
ICEM4N
- Proprietário Ion
Re: Open Vehicle Monitoring System
Volt era isto que te falei no almoco
https://www.openvehicles.com/
[img]http://i.imgur.com/Cf8OJS3.jpg[/img]
ICEM4N
- Proprietário Ion
Bom,
Mais depressa analisava isto e mais depressa ainda o CANION atualiza com ligação à internet.
Neste momento é possivel ver os dados online do canion, desde que este esteja logicamente ligado à net e termos outro telemovel também com canion....
Clones na vanguarda....... hehehe
- rnlcarlov
- Capacidade bateria: 41.1 Ah
Ver dados do canion online? Essa é nova para mim
ICEM4N
- Proprietário Ion
Actualização do dia 19/janrnlcarlov Escreveu:Ver dados do canion online? Essa é nova para mim
- rnlcarlov
Realmente o Canion atualizou-se há pouco tempo, mas ainda não tinha visto quais as novas funcionalidades. Pensei que era quase só estético.
ICEM4N
- Proprietário Ion
Basicamente tens agora info de amperes em carga.... Ligação à net.... Podes escolher ver a temperatura média, máxima ou minimarnlcarlov Escreveu:Realmente o Canion atualizou-se há pouco tempo, mas ainda não tinha visto quais as novas funcionalidades. Pensei que era quase só estético.
Assim as mais importantes são estss
- Apr
E ganhas uma bateria de 12V a mais para tratar de alimentar isso tudo.
- rnlcarlov
Se usar só o Canion com o brilho no mínimo, penso que tenho bateria que aguente algum tempo. Falta-me é outro dispositivo para receber os dados transmitidos.
