Accionar garantia na Amazon
Mensagem por Nonnus » 10 mar 2020, 00:05
Se alguém me puder esclarecer nesta questão agradecia.
Em julho de 2019 comprei um smartwatch na Amazon.es, hoje fiz uma reclamação via chat para accionar a garantia porque o relógio quando se faz chamadas não se houve a pessoa que esta a falar connosco. Agora vem a parte estranha de como a Amazon esta a pedir para proceder para me devolver o dinheiro.
Esta foi a minha conversa no chat com Amazon:
Yo: order number 403-0147714-*******
i need activate Warranty
Jakeline Nicole:please give me a moment to verify the data in your account and review the order
Yo: the watch when make calls I can't hear the voice of the caller
Jakeline Nicole:in this case I can help you with a refund of the money without however it is necessary to return the product and in this case as it is an international return you must pay the shipping costs with the carrier you hire however do not worry because you send us a copy of the invoice and we will also reimburse the shipping costs
Yo: sorry
i don´t understand
if i don´t need return the product why i need pay shipping costs?
don´t make sense to me
Jakeline Nicole: because i can't create a prepaid return label in portugal, but don't worry i'm telling you that you send us a copy of the invoice and we refund the shipping costs
Yo: ok
Jakeline Nicole:Once your return has been received and processed, we will send you an email with the confirmation of the refund, which will be made to the payment method used for the order. In general, the time that passes from the moment the carrier receives the package until the amount of the refund is reflected can be up to 2 weeks but because it is an international return it can take another week. Please note that, depending on your bank, the processing time for your refund may be longer.
Resumindo. Não querem que devolva o artigo danificado mas só me dão o dinheiro depois de receberem "qualquer coisa" da transportadora, e depois devolvem também o dinheiro que eu gastar com a transportadora se eu apresentar a factura.
Se eu percebo bem, vou enviar uma caixa vazia, pagar esse valor e só depois é que me devolvem o dinheiro e os portes.
Já alguém passou por isto? É assim que se processa o reembolso da Amazon?
Data de fabrico: 31 out 2016
Capacidade bateria: 82.34Ah
Re: Accionar garantia na Amazon
Mensagem por jfr2006 » 10 mar 2020, 00:33
Neste momento, é assim:
Envias o item, pagas tu os portes. Quando eles receberem o item, reembolsam-te no valor do artigo e pagam-te os portes até determinado valor.
corrisi
Mensagem por corrisi » 10 mar 2020, 03:17
Nonnus Escreveu:
10 mar 2020, 00:05
Yo: sorry
i don´t understand
Yo: ok
Viva. Deve ter havido um equívoco de comunicação ou interpretação da tua parte ou de ambos. Efetivamente tu tens que devolver o artigo original para a morada que eles te vão enviar para o email. Neste, vai constar a morada de destino, a fatura e um código de barras interno que deves colocar dentro da caixa da devolução. Basta imprimires, recortares e apenas preencher os dados do remetente. Está tudo praticamente pronto e é muito simples.
No passado algumas amazons europeias, nomeadamente a francesa e uk criavam etiquetas ou labels dos CTT já com código onde não era necessário o remetente pagar.
Quando efectuares o envio na transportadora, por exemplo CTT, pedes o comprovativo do pagamento. Convém sempre enviar em correio registado e com acesso a tracking number. Digitalizas o comprovativo de imediato e envias para o seguinte email:
charge-enquiries@amazon.es
Em algumas horas receberás um email a dar conta do reembolso do valor dos portes que pagaste para a devolução do artigo. Após a recepção deste na Amazon, a confirmação da sua recepção e respectivo reembolso do valor do artigo pode demorar até 2 semanas. Nesta fase é necessário ser paciente mas a Amazon praticamente nunca falha nestas situações.
Espero ter ajudado!
Nerusonu
Data de fabrico: 30 dez 2020
Capacidade bateria: 58Kwh
Mensagem por Nerusonu » 10 mar 2020, 09:21
É como diz o Corrisi, tens de devolver o produto e depois eles devolvem os valor do produto e dos portes.
Mensagem por Nonnus » 10 mar 2020, 10:33
corrisi Escreveu:
10 mar 2020, 03:17
Espero ter ajudado!
Isso que vocês dizem é o que faz sentido. Devolve-se o artigo e eles devolvem o dinheiro. E é o que vou fazer.
O que torna este caso estranho é começarem por dizer que não é preciso devolver o artigo, mas que tenho de enviar qualquer coisa por transportadora para activar a devolução do dinheiro. Reparem que eu friso que não faz sentido aquilo que estão a dizer.
Eu já recebi o email com as etiquetas e com os códigos de barras, vou enviar o relógio, se não o quiserem deitem-no fora. :whistle:
corrisi
Mensagem por corrisi » 10 mar 2020, 10:37
Nonnus Escreveu:
10 mar 2020, 10:33
corrisi Escreveu:
10 mar 2020, 03:17
Espero ter ajudado!
Tranquilo Nonnus. Procede em conformidade e tudo vai correr normalmente (bem)! 👍💪
Data de fabrico: 27 mar 2018
Mensagem por pemifer » 10 mar 2020, 10:47
Aparentemente não há "acionamentos de garantia", só devolução!
Fiquei agradavelmente surpreendido pela forma como tratam as devoluções.
Em baixo a minha interpretação do que se passou.
Preciso ativar a garantia
Por favor dê-me um momento para verificar os dados da sua conta e rever a sua encomenda
O relógio quando faço chamadas eu não consigo ouvir a voz da outra pessoa
Neste caso eu posso ajudar com o reembolso no entanto é necessário devolver o produto e neste caso como é uma devolução internacional terá de pagar os custos de transporte com a transportadora que contratar no entanto não se preocupe porque manda-nos uma cópia da fatura e nós tambem reembolsaremos os custos de transporte.
Yo: sorry
i don´t understand
Desculpe, não percebi, se não preciso de devolver o produto porque preciso de pagar custos de transporte?
Não faz sentido para mim.
Porque eu não posso criar uma "etiqueta" de devolução pré-paga em Portugal, mas não se preocupe estou a dizer-lhe que nos mande uma cópia da fatura e nós reembolsamos os custos de transporte
Yo: ok
ok
Assim que a devolução for recebida e processada, nós enviaremos-lhe um email com a confirmação do reembolso, que será feito pelo meio de pagamento usado na encomenda. Geralmente, o tempo que passa desde que o transportador recebe a encomenda e o montante do reembolso é refletido pode ser até 2 semanas porque é uma devolução internacional pode demorar mais 1 semana. Por favor tenha em atenção que, dependendo do seu banco, o tempo de processamento do reembolso pode ser ainda maior
noway
Data de fabrico: 26 set 2018
Mensagem por noway » 10 mar 2020, 12:40
Nonnus Escreveu:
10 mar 2020, 10:33
Hummm.... pelo texto que partilhaste.... eles nunca disseram que não tinhas de devolver o produto. Não estarás a fazer alguma confusão com a tradução?
Já agora disseste isto: "the watch when make calls I can't hear the voice of the caller" => tens um icon de bluetooth em baixo no telefone, quando estás a fazer chamadas. Tens de escolher que o som vai pelo smartphone e não por outro dispositivo qualquer que esteja ligado ao bluetooth. Vê lá se não é esse o teu problema.
RaaR
Mensagem por RaaR » 10 mar 2020, 13:08
A frase "in this case I can help you with a refund of the money without however it is necessary to return the product" dita pela assistência está errada. Tem ali um "without" a mais, tornando a frase agramatical e baralhando o Nonnus que não domina a língua inglesa e, portanto, se deixa enganar. Para o "without" fazer sentido, a frase teria que ser "I can help you with a refund of the money without requiring you to return the product" ou algo parecido.
A assistente deveria ter escrito: "In this case, I can help you with a refund of the money. However, it is necessary to return the product."
Quando, a seguir, o Nonnus disse que não estava a perceber e que não fazia sentido, a assistente não o terá percebido a ele e reiterou apenas que ele devia enviar o artigo.
Nerusonu
Mensagem por Nerusonu » 10 mar 2020, 14:10
pemifer Escreveu:
10 mar 2020, 10:47
Yo: sorry
i don´t understand
Yo: ok
ok
Já utilizei algumas vezes as devoluções deles e são sempre 5*, ao ponto de cada vez que preciso algo tecnológico, mesmo que pague um pouco mais às vezes, prefiro comprar neles
Voltar para “Off-Topic”
