A velocidades muito baixas o Leaf tem um pior desempenho
ruimegas
Gestor do Forum
Mensagem por ruimegas »
A velocidades muito baixas o Leaf tem um pior desempenho...e esta hein? :)
"Like many other Leaf owners in the US, I had my car in a "End Dependence" Day parade today. I cleared the onboard counter and prepared to see some double digit miles per kWh numbers. I was expecting the miles of slow driving to boost my efficiency through the roof. I was wrong.
Most of the parade was a steady 3-4 MPH which was just right for keeping my foot off the peddles. This creep speed was the same in D or ECO. When the parade ended, my miles per kilowatt rating was 1.8. This is worse than driving at 55MPH.
Granted, parades are not a use-case that Nissan needs to optimize for, I was just surprised. If slow driving 30-38MPH is good, I thought really slow driving would be great. Electric motors do not have the limited RPM range of ICE but they do have bands for optimal efficiency."
Em: http://www.mynissanleaf.com/viewtopic.php?f=31&t=4650
mikexilva
Moderador Global
Re: A velocidades muito baixas o Leaf tem um pior desempenho
Mensagem por mikexilva »
Suponho que tenha que ver com o atrito maior dos pneus no arranque do carro que tb se deve reglectir a velocidades muito baixas, mas se fosse com mais pressao nos pneus, ou ate com pneus de plastico rigido devia dar valores muito diferentes...
